How to configure and verify VLAN derivation for Instant AP (IAP) wired clients?
This article explains a new feature introduced in IAP OS version 6.2.1.0-3.3.0.0 wherein, we can now configure VLAN derivation for wired clients on IAPs. Prior to this version VLAN derivation for wired clients was not supported.
All the sample outputs in this article have been tested on IAP 105 running 6.2.1.0-3.3.0.0.
Environment : This article applies to all the IAPs running a minimum OS version of 6.2.1.0-3.3.0.0.
Through WebUI:
  1. Create a Wired profile with “Employee” Network by navigating to “More” on top right of the WebUI and select “wired”.
2. Select the “Client IP assignment” as Network assigned. The VLAN derivation rule will appear at the bottom. Create a new rule.
3. Choose an authentication method between mac authentication and 802.1x authentication and choose the authentication server as an external Radius server.
4. Complete the remaining wired profile configuration as per the requirement.
Through CLI:
wired-port-profile <Profile name>
   switchport-mode trunk| Access
   allowed-vlan <vlan IDs>
   native-vlan <VLAN ID>
   no shutdown
   access-rule-name <rule-name>
   speed auto
   duplex auto
   poe
   type employee
   auth-server <external server name>
   captive-portal disable
   dot1x
set-vlan AP-Group  equals Aruba 99
wlan access-rule permitall
rule any any match any any any permit
To verify and troubleshoot:
show clients wired debug” can display the content of wired client including the VLAN assigned.
show datapath user” on the client’s associated IAP can show the Vlan information of the connected client.
Version history
Revision #:
1 of 1
Last update:
‎07-03-2014 07:17 PM
Updated by:
Labels (1)
Contributors
