How to configure the MTU on IAP uplink and tunnel interfaces?
MVP
MVP
Q:
A:
Instant 6.4.3.1-4.2.0.0 introduces the mtu command to support the configuration of Maximum Transmission Unit (MTU) size for bridge (br0) and cellular uplink interfaces. The mtu command can be used to configures the MTU size for tunnel and br0 interfaces, and uplink interfaces such as 3G/4G. The configured MTU size is applied when the uplink changes.
Example:
Instant-4.2 (config) # mtu ?
<size>     size
Instant-4.2 (config) # mtu 1200 ?
<cr>
The mtu command is not supported on pre 6.4.3.1-4.2.0.0 versions.
Version history
Revision #:
2 of 2
Last update:
‎03-27-2017 07:50 AM
Updated by:
Labels (1)
Contributors
