Q:
How to console into Slave Instant AP through Aruba central ?
When we try to access console of a AP in central , it first connects to the VC/Master . From the VC we need to SSH to the salve IAP.
Please find the steps below
1. Login to central and select the group
2. Select the access point to console into .
3: Once you select the AP, on right hand top corner you will be able to see "Actions" button.
3. Click on that and you will be able to see console button.
4: When you click on the console button ,it will connect to virtual controller
5: From the VC console we can SSH to any slave IAP using the below command
ssh <slave ip > user admin
