How to disable USB functionality in IAP-205H?
MVP
MVP
Prior to 4.2 code, USB function is enable by default and we cannot modify it. How to disable USB functionality in IAP-205H?
In 4.2 code, we have a command to disable the USB functionality.
We need to reboot the IAP, only then the command will take effect.
Config:
To Disable USB functionality:
 24:de:c6:cf:5b:de# usb-port-disable
Note: Command takes effect after AP reboot.
To Enable USB functionality:
24:de:c6:cf:5b:de# no usb-port-disable
The #show ap-env command will tell us does the USB functionality is enabled or not.
24:de:c6:cf:5b:de# show ap-env
Antenna Type:Internal
usb-port-disable:1
0 ==> USB functionality enabled
1==> USB functionality disabled.
Version history
Revision #:
2 of 2
Last update:
‎07-30-2015 04:15 AM
Updated by:
Labels (1)
Contributors
