How to disable VHT functionality on 11ac supported IAPs?
MVP
MVP
Q:
A:
Prior to 4.2.1, for the VHT function on 11ac platforms, it was enabled by default and also had no interface to be disabled.
In some scenarios, it was necessary to disable the VHT so that 11ac APs can act as 11n APs. Hence from 4.2.1 code, we provide CLI and UI interfaces to disable/enable VHT if needed.
This function only takes effect on 5G of 11ac IAPs and can be configured both on wlan-ssid-profile and rf-dot11a-profile.
If configured on wlan-ssid-profile, it only takes effect on the certain SSID; If configured on rf-dot11a-profile, it can take effect on all SSID.
CLI commands:
•Disable VHT on wlan-ssid-profile
IAP (config) # wlan ssid-profile test
IAP (SSID Profile "test") # very-high-throughput-disable
•Enable VHT on wlan-ssid-profile
IAP (SSID Profile "test") # no very-high-throughput-disable
•Disable VHT on rf-dot11a-profile
IAP (config) # rf dot11a-radio-profile
IAP (RF dot11a Radio Profile) # very-high-throughput-disable
•Enable VHT on rf-dot11a-profile
IAP (RF dot11a Radio Profile) # no very-high-throughput-disable
WebUI:
Version history
Revision #:
2 of 2
Last update:
‎05-17-2016 03:58 PM
Updated by:
Labels (1)
Contributors
