How to disable radio on individual IAP?
MVP
MVP
Prior to 4.2, we can not disable per-ap radio.
For troubleshooting, it will be very much helpful if there is a option to disable radio per-ap.
In 4.2 code, we can disable radio without rebooting or deleting ssid, which is a per AP setting.
When disable a/g radio per ap, the ssid on this radio of this iap will be off.
1.CLI
      per-ap setting:
•dot11a-radio-disable
•no dot11a-radio-disable
•dot11g-radio-disable
•no dot11g-radio-disable
2. We cannot disable radio on per-iap using WebUi
      Not supported in 4.2
In show radio config we can cross check the config:
Version history
Revision #:
2 of 2
Last update:
‎07-30-2015 04:28 AM
Updated by:
Labels (1)
Contributors
Comments
daphi
We are on 6.4.2.0
When I ssh onto on of the APs it won't recognize the command. I get a parse error:
AP25-1E# dot11a-radio-disable
% Parse error
Is there a need to enter into the per AP mode or likewise?
