How to do encrypt disable on IAP?
Introduction : IAP OS commands are different from AOS commands and if we like to check the password without encryption "encrypt disable" will not work on IAP as this is for AOS.
For IAP command is:
(IAP)#show run no-encrypt
Version history
Revision #:
1 of 1
Last update:
‎07-17-2014 07:14 AM
Updated by:
Labels (1)
