Q: How to enable/disable USB uplink on Instant 4.2?
A: This article applies to Instant 4.2 and above.
Before Instant 4.2 USB function is enabled by default and will not be able to modify if we need to however from 4.2 and above we have an option to disable; find below.
Config by CLI
24:de:c6:cf:5b:de# usb-port-disable
Remind: Command takes effect after AP reboot.
24:de:c6:cf:5b:de#
24:de:c6:cf:5b:de# no usb-port-disable
24:de:c6:cf:5b:de# show ap-env
Antenna Type:Internal
usb-port-disable:1
Config by UI
Per AP setting-->Uplink-->USB port -->Enable/Disable
Note:
After the configure with usb port “usb-port-disable ” or “no usb-port-disable ” to reload the IAP IS required.
