Q:
How to find which device interface / dev name is mapped for which SSID on Instant APs?
What are the different dev names and dev numbers that we see in the "show datapath bridge" output?
A: The "show datapath bridge" command is usually used to find "on which vlan a given mac address is learned and which SSID it is destined to?"
In the "show datapath bridge" output, we can only see that every mac address has different dev interface number in the destination. Every device interface number has a separate device name like "aruba102", "aruba103", etc., mapped, but it doesn't actually show which SSID it corresponds to.
The SSID and the radio (2.4 or 5 Ghz) that is mapped for every dev name can be found in the "show ap debug system-status" output.
For example, we have the below SSIDs on this IAP,
Rajaguru-IAP# show network
Networks
Profile Name ESSID Clients Type Band Authentication Method Key Management IP Assignment Status Zone Coding Active
aruba-mesh aruba-mesh 0 guest all None None NAT Mode Enabled - Default Yes
OpenSystemAuthentication OpenSystemAuthentication 0 guest all None None NAT Mode Enabled - Default Yes
WEP-SharedKeyAuthentication WEP-SharedKeyAuthentication 0 voice all None WEP NAT Mode Enabled - Default Yes
PSK-PresharedKeyAuthentication PSK-PresharedKeyAuthentication 0 voice all None WPA2-AES NAT Mode Enabled - Default Yes
Mac-Auth Mac-Auth 0 voice all MAC Address None NAT Mode Enabled - Default Yes
Dot1x-Auth Dot1x-Auth 0 employee all Per User WPA2-AES NAT Mode Enabled - Default Yes
The different device numbers and the device names can be seen under the "Datapath Bridge Devices" of the "show datapath bridge" output.
The destination of different MAC addresses can be seen under "Datapath Bridge Table Entries" of th "show datapath bridge" output.
Rajaguru-IAP# show datapath bridge
Flags: F - source-filter, T - trusted, Q - tagged, I - IP
S - split-tunnel, B - bridge, M - mesh, P - PPPoE
C - content-filter, O - corp-access, h - to HAP, f - to FAP
h - dhcp-redirect b - blocked by STP
Dev Name VLANs PVID ACLs FramesRx FramesTx Flags
3 bond0 4095 1 0/0 106 9530532 5326100 FTQB
10 br0 0 1 105/0 0 129881 0 IB
13 aruba002 1 3333 134/0 0 5148787 6450209 B
14 aruba102 1 3333 134/0 0 29227 49709 B
15 aruba000 4095 1 0/0 106 0 2035763 TQBM
16 aruba003 1 3333 136/0 0 0 1609 B
17 aruba103 1 3333 136/0 0 17062 27950 B
18 aruba004 1 3333 139/0 0 0 1609 B
19 aruba104 1 3333 139/0 0 0 1609 B
20 aruba005 1 3333 141/0 0 0 1609 B
21 aruba105 1 3333 141/0 0 0 1609 B
22 aruba006 1 3333 100/0 0 0 1609 B
23 aruba106 1 3333 100/0 0 74 1609 B
24 aruba007 1 3333 100/0 0 0 1609 B
25 aruba107 1 3333 100/0 0 0 1609 B
Flags: P - Permanent, D - Deny, R - Route, M - Mobile, X - Xsec, A - Auth
AP Flags: X - Awaiting 1X reply, B - Block all non-1X traffic, F - Force bridge role
MAC VLAN Assigned VLAN Destination Flags AP Flags Bridge Role ACL
00:1A:1E:01:2F:58 1 1 dev3 0
18:64:72:C3:C3:20 3333 3333 local P 0
00:0B:86:B7:54:97 1 1 dev3 0
00:0C:29:88:EB:08 1 1 vlan 1 0
00:0B:86:BC:03:27 1 1 dev3 0
00:0B:86:D4:F0:43 1 1 dev3 0
00:1A:1E:09:D9:00 1 1 dev3 0
18:64:72:C3:C3:20 1 1 local P 0
18:64:72:C3:C3:1E 1 1 dev3 0
00:0B:86:B9:6C:8C 1 1 dev3 0
24:DE:C6:CD:6C:34 1 1 vlan 1 0
The SSIDs and the radio mapped for the different dev names can be found in the output of "show ap debug system-status" as below.
Rajaguru-IAP# show ap debug system-status
<TRUNCATED>
ifconfig output for bond0
bond0 Link encap:Ethernet HWaddr 18:64:72:C3:C3:20
inet6 addr: fe80::1a64:72ff:fec3:c320/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:9577190 errors:0 dropped:0 overruns:0 frame:0
TX packets:6926874 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:1855642418 (1.7 GiB) TX bytes:1943062181 (1.8 GiB)
Rx broadcast packet:0 Rx broadcast packet per second:0
Rx multicast packet:0 Rx multicast packet per second:0
Tx broadcast packet:0 Tx broadcast packet per second:0
Tx multicast packet:0 Tx multicast packet per second:0
ifconfig output for br0
br0 Link encap:Ethernet HWaddr 18:64:72:C3:C3:20
inet addr:10.29.162.254 Bcast:10.29.162.255 Mask:255.255.255.0
UP BROADCAST RUNNING ALLMULTI MULTICAST MTU:1300 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:3 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
IP Information
Reassemble Timeout packet 0
Reassemble required packet 0
Reassemble ok packet 0
Reassemble failed packet 0
Fragments received ok packet 15
Fragments failed packet 0
Fragments created packet 0
iwconfig output for aruba000
aruba000 IEEE 802.11na ESSID:"b712e65b2f86068b8315b25964213a5"
Mode:Master Frequency:5.805 GHz Access Point: 18:64:72:BC:32:10
Encryption key:A430-74D5-97CC-898E-341D-2940-AEC7-8B38 [2] Security mode:restricted
iwconfig output for aruba002
aruba002 IEEE 802.11na ESSID:"aruba-mesh"
Mode:Master Frequency:5.805 GHz Access Point: 18:64:72:BC:32:12
Encryption key:off
iwconfig output for aruba003
aruba003 IEEE 802.11na ESSID:"OpenSystemAuthentication"
Mode:Master Frequency:5.805 GHz Access Point: 18:64:72:BC:32:13
Encryption key:off
iwconfig output for aruba004
aruba004 IEEE 802.11na ESSID:"WEP-SharedKeyAuthentication"
Mode:Master Frequency:5.805 GHz Access Point: 18:64:72:BC:32:14
Encryption key:1122-3344-55 Security mode:restricted
iwconfig output for aruba005
aruba005 IEEE 802.11na ESSID:"PSK-PresharedKeyAuthentication"
Mode:Master Frequency:5.805 GHz Access Point: 18:64:72:BC:32:15
Encryption key:2D8A-B1F5-C6D8-5C88-1E6E-5911-3085-2360 [2] Security mode:restricted
iwconfig output for aruba006
aruba006 IEEE 802.11na ESSID:"Mac-Auth"
Mode:Master Frequency:5.805 GHz Access Point: 18:64:72:BC:32:16
Encryption key:off
iwconfig output for aruba007
aruba007 IEEE 802.11na ESSID:"Dot1x-Auth"
Mode:Master Frequency:5.805 GHz Access Point: 18:64:72:BC:32:17
Encryption key:A440-7A3D-CB32-17E2-C466-5926-6199-44FC [2] Security mode:restricted
iwconfig output for aruba102
aruba102 IEEE 802.11ng ESSID:"aruba-mesh"
Mode:Master Frequency:2.462 GHz Access Point: 18:64:72:BC:32:02
Encryption key:off
iwconfig output for aruba103
aruba103 IEEE 802.11ng ESSID:"OpenSystemAuthentication"
Mode:Master Frequency:2.462 GHz Access Point: 18:64:72:BC:32:03
Encryption key:off
iwconfig output for aruba104
aruba104 IEEE 802.11ng ESSID:"WEP-SharedKeyAuthentication"
Mode:Master Frequency:2.462 GHz Access Point: 18:64:72:BC:32:04
iwconfig output for aruba105
aruba105 IEEE 802.11ng ESSID:"PSK-PresharedKeyAuthentication"
Mode:Master Frequency:2.462 GHz Access Point: 18:64:72:BC:32:05
Encryption key:98EF-140A-7B49-11D0-D65D-A8C7-BB28-227B [2] Security mode:restricted
iwconfig output for aruba106
aruba106 IEEE 802.11ng ESSID:"Mac-Auth"
Mode:Master Frequency:2.462 GHz Access Point: 18:64:72:BC:32:06
Encryption key:off
iwconfig output for aruba107
aruba107 IEEE 802.11ng ESSID:"Dot1x-Auth"
Mode:Master Frequency:2.462 GHz Access Point: 18:64:72:BC:32:07
Encryption key:B520-18DC-D5DF-47FB-50CD-8870-B06A-D29E [2] Security mode:restricted
<TRUNCATED>
The bond0 is the bonded (eth) interface and the br0 is the bridging interface.
