How to pass IAP guest traffic to Controller
Symptoms
How to pass IAP guest traffic to Controller?
Diagnosis
Any Aruba IAP
Any Aruba Controller
Aruba OS 6.2 and above
Need to configure a DMZ Controller and want guest traffic from IAP to route to the Controller
Solution
These exceptions may be needed for management (such as for 802.1x Auth, Airwave pull, etc.).
Or when local bridging of corporate users is not feasible (as when IAP is deployed over the Internet).
If customer wants to use guest ssid on IAP same way as DMZ controller design.One easy way to do this would be, if that VLAN can be local, then the traffic should be able to bridge locally for that VLAN as it would not hit the routing profile of the VPN.
Version 3.3 added policy-based corporate access and source based routing.
In 3.2, you can create route exceptions when next hop uplink is known. For example, say that all 192.168 subnets are local to the branch:
routing-profile
route  192.168.0.0 255.255.0.0 192.168.1.1     <branch router
route  0.0.0.0  0.0.0.0  10.100.200.45   <primary VPN/DMZ controller
route  0.0.0.0  0.0.0.0  10.100.200.46   <secondary VPN/DMZ controller
routing-profile
Version history
Revision #:
2 of 2
Last update:
‎06-01-2014 08:25 PM
Updated by:
Labels (1)
Contributors
