How to stop the Debug-master-Beacon command from console
MVP
MVP
Q:
A:
-"Debug-master-beacon" This command is basically used to see the  master beacon  sent and the received .
-This command will  help in figuring out master discover issues.
 -You can run this command only from the console of the Ap.
- Once you run the command you can stop it only by typing the command
"No debug-master-beacon"
Sample command below
Version history
Revision #:
2 of 2
Last update:
‎07-29-2015 04:06 PM
Updated by:
Labels (1)
Contributors
