How to troubleshoot rogue on IAP
In this article  we will see the list of debugging and cli commands used to troubleshoot a rouge device in IAP.
List of command and debugging used to troubleshoot  Rogue on IAp.
Environment : All  IAP Versions.
Configure the following debugging level on the IAp to Capture the necessary output.
Within IAP cluster: Set security debugging to “Notice” level.
Click on “System” then “Show Advanced Options”
Under the “Monitoring” tab set the Security debugging level to “Notice”
Within the IAP cluster: When you see that the Rouge device is detected, run the below commands from the CLI of the IAP to  understand   how and why these devices are detected as rogue.
-show ap monitor ap-list  | include rogue
This command will show the list of devices detected
-show log security | include ids-ap
This  command will help us to find out the rouge BSSId and the Match MAC address
-show ap monitor ap-wired-mac  <BSSID as per security logs>
This command will help to find out the Match wired Mac .
-show tech-support
To get the complete config
Use the following command from the CLI to verify if there is a rouge device detected.
9c:1c:12:87:33:70  ethersphere-alpha           48    rogue        80211a-VHT-40   disable  23600/9407   0/0     wpa2-other-aes   0      23        23         0      no
From GUI
-Click on IDS  to view the rogue and interfering devices.
show log security | include ids-ap(You can also get this log on a syslog server)
“Jun 17 13:16:30 2014 10.64.99.209 sapd[1558]: <106000> <NOTI> <10.64.99.209 0.0.0.0> |ids-ap| AM 00:24:6c:24:0a:d8: Potentially rogue AP detected BSSID 6c:f3:7f:a8:9b:d0 SSID gotonet MATCH MAC 00:27:10:cf:f5:8c
show ap monitor ap-wired-mac 6c:f3:7f:a8:9b:d0  à BSSID from above log
Wired MAC Table
mac                age
00:27:10:cf:f5:8c 1h:27m:33s  -----MAC address from above log
00:1a:1e:00:66:b8  34m:32s
Version history
Revision #:
1 of 1
Last update:
‎11-04-2014 01:56 PM
Updated by:
Labels (1)
Contributors
