Requirement:How does IAP's communicate within cluster ?
Solution:IAP's use the following message for communication :
a) L2 Broadcast message for cluster maintenance and roaming
b) L3 unicast messages between IAPs (master and slave)
a) Master AP sends out an Layer 2 “beacon” message every second to notify that the master AP is currently active. This helps the :-
•New IAPs in discovering the master and join the cluster
•Existing IAPs can detect master failover and take over as master of cluster
b) Session request message for Layer 2 roaming
When a client roams between APs in a cluster, a session request message is used to transfer client session and role data between IAPs
L3 unicast messages between IAPs (master and slave):
•L3 unicast messages between IAPs (master and slave)
•UDP messages on port 8211 between master and slave APs for config sync, firmware upgrade and control-plane messaging between IAPs
Configuration:There is no explicit configuration required for the same.
VerificationL2 Messages :
L3 Messages:
