IAP on Juniper EX switch
Question Why does Aruba Instant APs connected to Juniper EX switch don't form a cluster?
Environment Aruba Instant APs connected to Juniper EX switch.
With Juniper EX switches; if the native vlan is included in the member vlan; it would be tagged. This would result in APs not able to communicate to each other consequently not join the cluster.
Example ::
family ethernet-switching {
                    port-mode trunk;
                    vlan {
                        members [ VLAN5 VLAN200 VLAN100];    <-- Native VLAN Included
                    native-vlan-id VLAN100;
To have the native vlan untagged; it should only be defined under native-vlan-id.
Example ::
                    port-mode trunk;
                    vlan {
                        members [ VLAN5 VLAN200];    <-- Native VLAN NOT Included
Juniper KB Article :: https://kb.juniper.net/InfoCenter/index?page=content&id=KB17419
Version history
Revision #:
1 of 1
Last update:
‎07-11-2014 04:00 PM
Labels (1)
Contributors
Comments
Gary Hahn
I can confirm horribly intermittent IAP operation, intermittent AP to AP pings, intermittent lack of ARP responses, and various other maladies when this is the case.  Removing the native VLAN from the members resolves it all.   Thank you!
