IGC Group with different IAP running different firmware result mismatch.
what could cause if IAP running different firmware on same IGC group?
Environment: Though the wireless profiles configuration and security setting are same, IAP/Cluster running different firmware cannot reside in same IGC Group.
 Instant devices running different firmware versions cannot reside in the same IGC group. Each IGC group can only include devices with the same firmware version because the configuration setting are Group based which are build based on specific firmware and when there are IAPs with different firmware are added then feature of base firmware for the group may not be available and that create issue while managing configuration.
Version history
Revision #:
2 of 2
Last update:
‎11-09-2014 12:05 AM
Labels (1)
