In certain circumstances, valid AP's in the network might get classified as rogue or interferring. With the steps mentioned in the article, we can re-classify the IDS state of the AP.
Valid clients connecting to rogue AP will be de-authenticated even though the rouge AP in question is a valid on the network. In such case, re-classifying the rogue AP as valid will avoid clients from getting de-authenticated.
Environment : This applies to all Aruba Instant Access Points running InstantOS version 4.0 and above.
Network Topology : Network can consist of Aruba Instant AP's, Aruba Campus AP's and any other Vendor AP.
To do the re-classification the below steps need to be performed:
Check the current IDS state of the AP.
Once we identify the AP which needs to be re-classified, we need to understand the phy_type and rap_types that are required to do the re-classification.
Below are the config steps:
We are reclassifying a Interfering AP as rogue AP
24:de:c6:b9:64:18 is the bssid of the AP with SSID "aruba-ap"
The AP "24:de:c6:b9:64:18" is being re-classified as "valid" AP.
- Below is the command used in the reclassification process.
- 1 is the "phy_type" and 0 is the "rap_type"
- 1 = "a" band
- 0 = "valid"
