Instant DNS ACL
Aruba Instant's captive portal whitelist URL option would only work with HTTP sites. There maybe scenarios where permitting HTTPS location is required (example Apple App Store / Google Play Store to download apps). For such scenarios, domain-name ACLs can be used.
  • This Article applies to Aruba Instant 4.0 or above.
  • As of 4.0 release, we can support a max of 127 domains and 2048 IP address mappings of the 127 domains
Environment : Any Instant deployment running 4.0 release or above with domain-name ACL.
Network Topology :
|                  Switch                    |
     |      IAP1     |          |     IAP2     |
     |    (Master)   |          |    (Slave)   |
With 4.0 release, we have additional option of domain name for Destination
The ACL is mapped to the role
From the client, we can initiate traffic to the specified URL and validate traffic is going by using show datapath session command.
The ACL domains which have been created in config and whether they are in use (i.e. mapped to role) can be validated by using command "show acl domain"
show acl domains
role-domain
role-domain  inused
facebook.com   used(1)
To check if user is falling to right role, we would use "show datapath user" and "show datapath acl <ID>"
show datapath user
Datapath User Table Entries
Flags: P - Permanent, W - WEP, T- TKIP, A - AESCCM
       R - ProxyARP to User, N - VPN, L - local, I - Intercept, D - Deny local routing
FM(Forward Mode): S - Split, B - Bridge, N - N/A
       IP              MAC           ACLs    Contract   Location  Age    Sessions   Flags     Vlan  FM
192.168.103.128  AC:A3:1E:C3:32:B4   105/0      0/0     0         1        2/65535  P           1   B
0.0.0.0          20:02:AF:1E:4B:5E   109/0      0/0     0         0        0/65535  P           4   B
172.16.99.1      AC:A3:1E:C3:32:B4   105/0      0/0     0         19       2/65535  P           1   B
172.16.99.241    00:08:22:60:3D:12   109/0      0/0     0         0        3/65535              4   B
# show datapath acl 109
Datapath ACL 138 Entries
Flags: P - permit, L - log, E - established, M/e - MAC/etype filter
       S - SNAT, D - DNAT, R - redirect, r - reverse redirect m – Mirror
       I - Invert SA, i - Invert DA, H - high prio, O - set prio, C - Classify Media
       A - Disable Scanning, B - black list, T - set TOS, 4 - IPv4, 6 - IPv6
       d - Domain DA
 1:  any  any  17 0-65535 8209-8211  P4
 2:  any  facebook.com  any  Pd4
 3:  any  any  any  P4
Each AP would intercept and cache the DNS requests and responses from client devices. This cache can be checked using command "show datapath dns-id-map".
Hash index entries:
Entry:1 id:0 www.facebook.com
173.252.120.6
1 entries
Version history
Revision #:
1 of 1
Last update:
‎04-08-2015 11:25 AM
Updated by:
Labels (1)
Contributors
