Is it possible to reduce the cell size in IAP?
MVP
MVP
Q:
A:
Cell size reduction knob is introduced from 4.2.1.0 code.
This knob can be configured only through CLI.
 (config) # rf dot11a-radio-profile
(RF dot11a Radio Profile) # cell-size-reduction <reduction>
(config) # rf dot11g-radio-profile
(RF dot11g Radio Profile) # cell-size-reduction <reduction>
•Value is specified in dB
•Reduces the Rx-sensitivity of the radio for all 802.11 frames by the specified value.
•The radio will be deaf to any signal below the specified value
Version history
Revision #:
2 of 2
Last update:
‎05-17-2016 04:05 PM
Updated by:
Labels (1)
Contributors
