Is it possible to segregate the Guest and corporate traffic from IAP225s using E0 for corp and E1 for guest.
Question
Question: Is it possible to segregate the Guest and corporate traffic from IAP225s using E0 for corp and E1 for guest.
Answer
Environment: IAP-225 series model APs
The guest and corporate traffic from IAP225s using E0 for corp and E1 for guest is not supported.
This kind of setup can be done using controller Architecture but not with IAP Architecture.
Version history
Revision #:
2 of 2
Last update:
‎11-08-2014 11:59 PM
Labels (1)
Contributors
