Is multicast traffic supported by Aruba Instant?
Environment : This article applies to Aruba Instant Access Points.
The Aruba mobility controller supports multicast and video optimization features such as IGMP Snooping and Proxy and dynamic multicast optimization.
Aruba Instant does not offer multicast intelligence like the mobility controller or the multicast router does. Instant AP forwards multicast traffic for a given VLAN from the wired network into the wireless network and vice-versa.
All multicast routing and IGMP intelligence must be handled by the upstream multicast router. Multicast traffic is not permitted on guest-type SSIDs. This is done to filter out Broadcast and multicast traffic from guest wireless LANs inorder to preserve the airtime and battery life. (ARP broadcasts will be excluded).
Incase,  if an administrator wanted to enable multicast to support Bonjour for Apple clients, then he can enable it under Services -> AirGroup tab on WebUI.
Below are the listed steps and the image:
  • Login to IAP web interface
  • From the top-right menu, point to "More" and select "Services"
  • On the "AirGroup" tab.
From the command line:
(Instant Access Point)#
(Instant Access Point)#configure terminal
(Instant Access Point)(config)# airgroup
(Instant Access Point)(airgroup)# enable-guest-multicast
(Instant Access Point)(airgroup)# end
(Instant Access Point)# commit apply
Note: "Commit Apply" command is similar to "Write Memory" command that saves the configuration.
Version history
Revision #:
1 of 1
Last update:
‎07-01-2014 01:42 PM
Updated by:
Labels (1)
Contributors
