Limitations of IAP-92/93 from Aruba Instant and above
What are the limitations of IAP-92/93 from Aruba Instant and above?
The following features are no longer available for IAP-92/93 starting from and above:
1. AirGroup
2. Internal RADIUS server for 802.1x authentication
3. EAP Termination
4. Authentication Survivability
5. LLDP integration
The features listed above may be configured through Instant CLI/Web UI and AirWave Management Platform, but will have no effect on IAP-92/93. In a cluster running Instant 6.4.x.x-4.1.x.x, only IAP-92/93 will have the above limitations.
In order to conserve memory, IAP-92/93 is now restricted to a single active CLI session, either through console, SSH, or telnet.
An error message "All CLI sessions are in use" is displayed if the user attempts to open multiple sessions.
Version history
Revision #:
2 of 2
Last update:
‎03-07-2016 11:46 AM
Updated by:
Labels (1)
