Modem 340U SIM PIN Lock
MVP
MVP
Introduction:
The SIM PIN LOCK function is used to prevent fraud use by locking the modem via SIM lock, modem/SIM will be locked if this function is enabled, and IAP will unlock the modem during power-on by executing the related unlock command. Before we can not modify this PIN but in 4.2 it will be modifiable.
Feature:
  • SIM PIN can be enable/disable/renew and /puk-unlock by CLI with IAP on 4.2.
  • PIN and PUK CODE are provide by ISP, please ensure them before we try to setup this function.
  • PIN lock/unlock only support from CLI to setup, and only can setup with modem is manual configuration status.
Modem 340U SIM PIN Lock CLI configuration:
00:0b:86:8f:51:10# configure terminal
We now support CLI commit model, please type "commit apply" for configuration to take effect.
(config) # cellular-uplink-profile
00:0b:86:8f:51:10 (cellular-uplink-profile) # ?
pin-enable
pin-puk
pin-renew
00:0b:86:8f:51:10 (cellular-uplink-profile) # no pin-enable ?
<pin_current_used>     pin current used
Enable/disable PIN
00:0b:86:8f:51:10 (config) # cellular-uplink-profile
00:0b:86:8f:51:10 (cellular-uplink-profile) # pin-enable 1234
00:0b:86:8f:51:10 (cellular-uplink-profile) # no pin-enable 1234
PIN enable/ disable check.
00:0b:86:8f:51:10# show cellular config
Comm USB Plugged in: Vendor_ID=12d1 Product_ID=1506
Cellular configuration
Type            Value
4g-usb-type
usb-type        huawei-cdc
usb-dev         0x12d11506
usb-tty         ttyUSB1
usb-init
usb-auth-type
usb-user
usb-passwd
usb-dial
usb-modeswitch
pin-code        1234
modem-isp
modem-country
Supported Country list
Country list
China
UK
Germany
India
Supported ISP list
ISP list
China Unicom
Vodafone
T-Mobile
Airtel
modem status summary:USB modem attached with detect successful
PIN locked for 3 times incorrect input.
PIN-enable only be enabled with a correct password, if password  input incorrect for 3 times the SIM card will locked.
00:0b:86:8f:51:10# conf terminal
we now support CLI commit model. please type "commit apply" for configuration to take effect.
00:0b:86:8f:51:10 (cellular-uplink-profile) # end
00:0b:86:8f:51:10# commit apply
committing configuration...
Command fail, PIN is not correct, if failed more than 3 times you will need PUK to unlock the PIN
00:0b:86:8f:51:10 (cellular-uplink-profile) # pin-enable 12345
00:0b:86:8f:51:10# wed Jun 24 08:23:50 2015 ppp_device_event: dev ppp0 is down, is_3g:0, is_pppoe_uplink:0
Jun 24 08:23:54 udhcpc[3850]: Received SIGTERM
PIN-PUK unlock PIN
00:0b:86:8f:51:10# config terminal
00:0b:86:8f:51:10 (cellular-uplink-profile) # pin-puk 75944712 123456
Command success, new PIN will take effect after AP reboot.
IAP UNLOCK PIN after reboot
usbcore: registered new interface driver option
option: v0.7.2:USB Driver for GSM modems
modem locked by PIN, unlock it successfully
usbcore: deregistering interface driver usb-storage
uniform CD-ROM driver unloaded
Note:
PIN-PUK, is a safety code for unlock PIN, if  PUK input incorrect for 10 times, the SIM will lock forever, can not use it anymore.
After PIN enable the SIM card need unlock for each time,  IAP will unlock it when the booting up.
PIN-RENEW
00:0b:86:8f:51:10 (cellular-uplink-profile) # pin-renew 123456 1234
00:0b:86:8f:51:10#
Type               Value
4g-usb-type
usb-type        huawei-cdc
usb-dev         0x12d11506
usb-tty         ttyUSB1
usb-init
usb-auth-type
usb-user
usb-passwd
usb-dial
usb-modeswitch
pin-code        1234
Version history
Revision #:
2 of 2
Last update:
‎11-25-2015 02:08 PM
Updated by:
Labels (1)
Contributors
