Opportunistic Key Caching on IAP
Few points about Opportunistic Key Caching (OKC)
  1. Basically enabling OKC helps to avoid full 802.1X authentication to any new AP the client roams.
  2. Also it overcome the Limit on how many PMKSAs client can cache.
  3. Helps to Share the PMK key info across all the APs in the swarm.
  4. OKC is enabled by default.
  5. Default PMK Cache time is 8 hrs as like controller configuration.
  6. Currently supported only on single swarm
  7. OKC is also applicable only to WPA2-Enterprise (WPA-2& WPA)
Note:-  This feature supports only from Instant 4.0 and make sure client supports OKC  for e.g Windows clients, Polycom Spectralink 8400 phones etc..
With out & WIth OKC feature
How to configure OKC from WEBUI:-
From CLI:-
Commands to see the PMKcache table
Here is the sample of auth-trace-buf output
To verify the debug mgmt frames
Few troubleshooting steps to configure syslog and user-debug
Thank you.
Version history
Revision #:
1 of 1
Last update:
‎06-27-2014 05:55 AM
Updated by:
Labels (1)
Contributors
