SUPPORTED ARUBA PART NUMBERS FOR IAP AND SWITCHES ON ACTIVATE
MVP
MVP
Q:
What is the supported Aruba Part Numbers for IAP and Switches on Activate
A:
Aruba Central will not allow addition/connectivity of any device if device part number doesn’t match with one of the part numbers given below.
ARUBA DEVICES
IAPs
'IAP-104', 'IAP-104-F1', 'IAP-104-IL', 'IAP-104-JP', 'IAP-104-US', 'IAP-104-US-F1', 'IAP-104-USF1', 'IAP-105', 'IAP-105-F1', 'IAP-105-IL', 'IAP-105-JP', 'IAP-105-US', 'IAP-105-US-F1', 'IAP-105-USF1', 'IAP-134', 'IAP-134-F1', 'IAP-134-IL', 'IAP-134-JP', 'IAP-134-US', 'IAP-134-US-F1', 'IAP-134-USF1', 'IAP-135', 'IAP-135-F1', 'IAP-135-IL', 'IAP-135-JP', 'IAP-135-US', 'IAP-135-US-F1', 'IAP-135-USF1', 'IAP-175AC', 'IAP-175AC-F1', 'IAP-175AC-IL', 'IAP-175AC-JP', 'IAP-175AC-US', 'IAP-175AC-USF1', 'IAP-175P', 'IAP-175P-F1', 'IAP-175P-IL', 'IAP-175P-JP', 'IAP-175P-US', 'IAP-175P-USF1', 'IAP-23', 'IAP-23-F1', 'IAP-23-IL', 'IAP-23-JP', 'IAP-23-US', 'IAP-23-US-F1', 'IAP-23-USF1', 'IAP-23P', 'IAP-92', 'IAP-92-F1', 'IAP-92-IL', 'IAP-92-JP', 'IAP-92-US', 'IAP-92-US-F1', 'IAP-92-USF1', 'IAP-93', 'IAP-93-F1', 'IAP-93-IL', 'IAP-93-JP', 'IAP-93-NFR', 'IAP-93-US', 'IAP-93-US-F1', 'IAP-93-USF1', 'IAP-9x', 'RAP-108', 'RAP-108-F1', 'RAP-108-JP', 'RAP-108-US', 'RAP-108-USF1', 'RAP-109', 'RAP-109-F1', 'RAP-109-JP', 'RAP-109-US', 'RAP-109-USF1', 'RAP-155', 'RAP-155-JP', 'RAP-155-US', 'RAP-155-USF1', 'RAP-155P', 'RAP-155P-JP', 'RAP-155P-US', 'RAP-155P-USF1', 'RAP-3WN', 'RAP-3WN-F1', 'RAP-3WN-IL', 'RAP-3WN-JP', 'RAP-3WN-US', 'RAP-3WN-US-F1', 'RAP-3WN-USF1', 'RAP-3WNP', 'RAP-3WNP-F1', 'RAP-3WNP-JP', 'RAP-3WNP-US', 'RAP-3WNP-USF1', 'IAP-114', 'IAP-114-F1', 'IAP-114-JP', 'IAP-114-US', 'IAP-114-USF1', 'IAP-114-RW', 'IAP-114-RWF1', 'IAP-115', 'IAP-115-F1', 'IAP-115-JP', 'IAP-115-US', 'IAP-115-USF1', 'IAP-115-RW', 'IAP-115-RWF1', 'IAP-224', 'IAP-224-F1', 'IAP-224-JP', 'IAP-224-US', 'IAP-224-USF1', 'IAP-224-RW', 'IAP-224-RWF1', 'IAP-225', 'IAP-225-F1', 'IAP-225-JP', 'IAP-225-US', 'IAP-225-USF1', 'IAP-225-RW', 'IAP-225-RWF1', 'IAP-103', 'IAP-103-US', 'IAP-103-USF1', 'IAP-103-JP', 'IAP-103-RW', 'IAP-103-RWF1', 'IAP-103H-US', 'IAP-103H-USF1', 'IAP-103H-JP', 'IAP-103H-RW', 'IAP-103H-RWF1', 'IAP-274', 'IAP-274-US', 'IAP-274-USF1', 'IAP-274-JP', 'IAP-274-RW', 'IAP-274-RWF1', 'IAP-275', 'IAP-275-US', 'IAP-275-USF1', 'IAP-275-JP', 'IAP-275-RW', 'IAP-275-RWF1', 'HP-350', 'HP-350-F1', 'HP-350-JP', 'HP-350-US', 'HP-350-RW',  'HP-350-USF1', 'HP-355', 'HP-355-F1', 'HP-355-JP', 'HP-355-US', 'HP-355-RW', 'HP-355-USF1', 'HP-365', 'HP-365-F1', 'HP-365-JP', 'HP-365-US', 'HP-365-RW', 'HP-365-USF1', 'IAP-204', 'IAP-204-US', 'IAP-204-USF1', 'IAP-204-RW', 'IAP-204-RWF1', 'IAP-204-JP', 'IAP-205', 'IAP-205-US', 'IAP-205-USF1', 'IAP-205-RW', 'IAP-205-RWF1', 'IAP-205-JP', 'IAP-214', 'IAP-214-US', 'IAP-214-USF1', 'IAP-214-RW', 'IAP-214-RWF1', 'IAP-214-JP', 'IAP-215', 'IAP-215-US', 'IAP-215-USF1', 'IAP-215-RW', 'IAP-215-RWF1', 'IAP-215-JP', 'IAP-205H', 'IAP-205H-JP', 'IAP-205H-US', 'IAP-205H-USF1', 'IAP-205H-RW', 'IAP-205H-RWF1', 'IAP-205H-IL', 'IAP-277', 'IAP-277-JP', 'IAP-277-US', 'IAP-277-USF1', 'IAP-277-RW', 'IAP-277-RWF1', 'IAP-277-IL', 'IAP-228', 'IAP-228-JP', 'IAP-228-US', 'IAP-228-USF1', 'IAP-228-RW', 'IAP-228-RWF1', 'IAP-228-IL', 'IAP-324', 'IAP-324-JP', 'IAP-324-US', 'IAP-324-USF1', 'IAP-324-RW', 'IAP-324-RWF1', 'IAP-324-IL', 'IAP-325', 'IAP-325-JP', 'IAP-325-US', 'IAP-325-USF1', 'IAP-325-RW', 'IAP-325-RWF1', 'IAP-325-IL'
​Switches
'S1500-12P', 'S1500-12P-US', 'S1500-12P-IL', 'S1500-24P', 'S1500-24P-US', 'S1500-24P-IL', 'S1500-48P', 'S1500-48P-US', 'S1500-48P-IL', 'S2500-24P', 'S2500-24P-IL', 'S2500-24P-US', 'S2500-24T', 'S2500-48P', 'S2500-48P-IL', 'S2500-48P-US', 'S2500-48T', 'S3500-24F', 'S3500-24P', 'S3500-24PF', 'S3500-24P-IL', 'S3500-24P-US', 'S3500-24T', 'S3500-48P', 'S3500-48P-IL', 'S3500-48P-US', 'S3500-48PF', 'S3500-48PF-IL', 'S3500-48PF-US', 'S3500-48T', 'S3500-4x10G'
Version history
Revision #:
2 of 2
Last update:
‎03-29-2017 12:30 PM
Updated by:
Labels (1)
Contributors
