SUPPORTED HP PART NUMBERS FOR IAP AND SWITCHES ON ACTIVATE
MVP
MVP
Q:
What is the supported HP Part Numbers for IAP and Switches on Activate
A:
Aruba Central will not allow addition/connectivity of any device if device part number doesn’t match with one of the part numbers given below.
HP Devices
IAPs
'JL185A', 'JL186A', 'JL187A', 'JL191A', 'JL190A', 'JL184A', 'JL235A', 'JL230A', 'JL233A', 'JL188A', 'JL189A', 'JX780A', 'JX781A', 'JX783A', 'JX782A', 'JX784A', 'JX785A', 'JX787A', 'JX786A', 'JW190A', 'JW191A', 'JW189A', 'JX788A', 'JX789A', 'JX790A', 'JX791A', 'JX792A', 'JX793A', 'JX794A', 'JX796A', 'JX795A', 'JX797A', 'JX798A', 'JW194A', 'JW195A', 'JW193A', 'JW196A', 'JW197A', 'JW200A', 'JW201A', 'JW199A', 'JW202A', 'JW203A', 'JX799A', 'JX800A', 'JX802A', 'JX801A', 'JX803A', 'JX804A', 'JX805A', 'JX806A', 'JX808A', 'JX807A', 'JX809A', 'JX810A', 'JX817A', 'JX818A', 'JX819A', 'JX820A', 'JX821A', 'JX811A', 'JX812A', 'JX814A', 'JX813A', 'JX815A', 'JX816A', 'JW206A', 'JW207A', 'JW205A', 'JW208A', 'JW209A', 'JW212A', 'JW213A', 'JW211A', 'JW214A', 'JW215A', 'JW216A', 'JW217A', 'JW219A', 'JW218A', 'JW222A', 'JW223A', 'JW221A', 'JW224A', 'JW225A', 'JW228A', 'JW229A', 'JW227A', 'JW230A', 'JW231A', 'JW234A', 'JW236A', 'JW233A', 'JW235A', 'JW237A', 'JW240A', 'JW242A', 'JW239A', 'JW241A', 'JW243A', 'JW245A', 'JW244A', 'JW246A', 'JW247A', 'JW248A', 'JW249A', 'JW250A', 'JW253A', 'JW251A', 'JW252A', 'JW254A', 'JW255A', 'JW258A', 'JW256A', 'JW257A', 'JW260A', 'JW259A', 'JW261A', 'JW262A', 'JW263A', 'JW319A', 'JW321A', 'JW317A', 'JW318A', 'JW320A', 'JW322A', 'JW325A', 'JW327A', 'JW323A', 'JW324A', 'JW326A', 'JW328A', 'JW264A', 'JW267A', 'JW268A', 'JW266A', 'JW269A', 'JW270A', 'JW273A', 'JW274A', 'JW272A', 'JW275A', 'JW276A', 'JW278A', 'JW279A', 'JW281A', 'JW282A', 'JW284A', 'JW285A', 'JW287A', 'JW288A', 'JW291A', 'JW292A', 'JW289A', 'JW290A', 'JW293A', 'JW294A', 'JW297A', 'JW298A', 'JW296A', 'JW299A'
Switches
'JW673A', 'JW671A', 'JW672A', 'JW668A', 'JW670A', 'JW665A', 'JW659A', 'JW660A', 'JW661A', 'JW662A', 'JW663A', 'JW146A'
Version history
Revision #:
2 of 2
Last update:
‎03-29-2017 12:27 PM
Updated by:
Labels (1)
Contributors
