Static and ARM assigned channel and power In Instant AP
MVP
MVP
Q:
How to set static power and then allow ARM assigned channel and power in Instant AP from Command line interface?
A:
Using the  below commands, we can set static power and channel in Instant AP in a and g-band.
a-channel                          static 5 GHz channel and power... set it to 0 for ARM assigned
g-channel                          static 2.4 GHz channel and power... set it to 0 for ARM assigned
Set the static power and channel as below:
a-channel 40 15
g-channel 11 12
To set the power assigned by ARM then we need to set it to 0 as below:
a-channel 0 0
g-channel 0 0
Note: This is AP specific configuration.
Version history
Revision #:
2 of 2
Last update:
‎05-20-2016 10:23 AM
Updated by:
Labels (1)
Contributors
