Steps to upload custom certificates from Central for Aruba Instant
MVP
MVP
Q:
Steps to upload custom ceritficate from Central for Aruba Instant
A:
From Central 2.2.7 we have option to upload custom certificates i.e CA and Server certificates for APs
Steps to upload the certificate
1: Select the Group for which we need to upload the certificate
2: Select Configuration > Security and click certificate
3: Under Certificate option we have Certificate store and Certificate Usage
4: Under Certificate store upload the certificates i.e server and CA . Please note passphrase is mandatory
5: In Certificate Usage map the uploaded certificates depending upon the usage i.e Captive portal, CA , Auth Server, Radsec
Please note : For Captive portal authentication HTTP/HTTPS post URL has to been changed according to the certificate CN name . Currently central does not have option to edit the URL according to custom certificate CN .Customer has to contact support for that change
Version history
Revision #:
2 of 2
Last update:
‎03-24-2017 07:59 PM
Updated by:
Labels (1)
Contributors
