USB disable/enable on IAP
MVP
MVP
Q:
Is there an option to disable/enable USB ports on IAP?
A:
USB port is enabled by default in earlier Instant versions and it cannot be modified. Starting 4.2, it provides WLAN user an option to enable or disable per his/her requirement.
Note: Any changes made to USB profile will take effect only after rebooting that AP.
Enable/Diable USB Port using CLI:
24:de:c6:cf:5b:de# usb-port-disable
Remind: Command takes effect after AP reboot.
24:de:c6:cf:5b:de#
24:de:c6:cf:5b:de# no usb-port-disable
24:de:c6:cf:5b:de# show ap-env
Antenna Type:Internal
usb-port-disable:1
Enable/Diable USB Port using WebUI:
Version history
Revision #:
2 of 2
Last update:
‎07-31-2015 07:50 AM
Updated by:
Labels (1)
Contributors
