View RSSI of clients in Instant
MVP
MVP
Q:
How to view the RSSI of the client in Aruba Instant AP?
A:
RSSI is the actual signal strength seen by the AP for the client.
RSSI can be derived by 'Noise Floor - SNR'. Example calculation as below:
  • SNR = 35
  • Noise Floor = 95
  • RSSI = 95 - 35  => 60
In Aruba Instant AP's below commands will help in showing the RSSI and SNR of the client along with the Noise Floor for that particular channel:
18:64:72:c6:d7:28# show clients
Client List
Name           IP Address     MAC Address        OS      ESSID      Access Point       Channel  Type  Role       Signal    Speed (mbps)
khils-iPhone   172.31.98.146  d8:1d:72:7d:75:67  iPhone  ak-iap     18:64:72:c6:d7:28  52       AC    ak-iap     65(good)  86(good)
  • Signal = SNR
18:64:72:c6:d7:28# show ap monitor sta-list | include d8:1d:72:7d:75:67
Monitored Client Table
mac                bssid              essid             channel  sta-type     auth  phy-type        dt/mt       ut/it     snr  rssi  cl-delay
d8:1d:72:7d:75:67  18:64:72:ed:72:90  ak-iap            52       valid        yes   80211a-VHT-20   2701/2701  6/5        65   30    -
  • SNR = 65
  • RSSI = 30
18:64:72:c6:d7:28# show ap debug radio-stats 0 | include Noise
Current Noise Floor                 95
Few other commands to check the Noise Floor and SNR:
  • # show ap arm rf-summary => to check NF
  • # show ap debug client-table => to check SNR
Version history
Revision #:
2 of 2
Last update:
‎11-10-2017 07:41 AM
Updated by:
Labels (1)
Contributors
