What are requirements to form Instant AP cluster with mixed IAP models?
Question: What are requirements to form Instant AP cluster with mixed IAP models?
Environment:This articles applies to all Aruba Instant Access Point running any version of InstantOS.
When going with the IAP cluster-based design, the IAPs can be deployed either as a homogenous cluster (same-model IAPs) or mixed IAPs cluster with different classes.
The IAP models are basically divided into four classes based on their hardware and capability. Below are the classes and respective Instant AP models:
Aries: RAP-155, RAP-155P
Cassiopeia: IAP-134, IAP-135
Orion: IAP-92, IAP-93, IAP-105, IAP-175, RAP-3WN, RAP-3WNP
Pegasus: RAP-108, RAP-109
In a cluster of mixed IAP cluster, following requirements need to be considered:
  • All Instant APs participating in the mixed cluster should run the same firmware.
  • All the Instant APs, including the Virtual Controller (VC) should be configurable to run on a common Country Code (CC). All the Instant APs, should be of country code  US (United Stated) or IL IIsrael) or JP (Japan) orRoW (Rest of World)
Version history
Revision #:
1 of 1
Last update:
‎07-01-2014 04:43 PM
Labels (1)
Contributors
Tags (1)
