What are the enhancements made in the Accounting options for Captive Portal network in Aruba Instant version 6.2.1.0-3.3.0.0 and how do I configure them?
This article explains the new accounting options introduced in IAP OS version 6.2.1.0-3.3.0.0.
There are two Accounting modes –
  1. Association mode Accounting - accounting starts after Captive Portal client association and stops after clients disassociation.
  2. Association mode accounting - accounting starts after Captive Portal authentication and stops after clients logout.
This article applies to all the IAPs running a minimum OS version of 6.2.1.0-3.3.0.0
Environment : All the sample outputs in this article has been tested on IAP 135 running 6.2.1.0-3.3.0.0.
  1. Create a New SSID and navigate to Security
  2. Select the splash page as "External-Radius Authentication" or "External- Authentication text".
  3. Select "association" or "authentication" from the accounting drop down as show below:
Additionally, we can configuration accounting interval in minutes.
The command “show ap debug auth-trace-buf” shows the details of accounting messages being exchanged.
Version history
Revision #:
1 of 1
Last update:
‎07-03-2014 05:04 PM
Updated by:
Labels (1)
Contributors
