What cause IAP does not have a Cloud Activate Key?
Product and Software: This article applies to all (Instant Access Points) IAPs.
For Cloud Activation key you have to check IAP WebUI interface | Maintenance | About
However, above we do not see "Cloud Activation Key".
Instant AP is unable to communicate with device.arubanetworks.com via HTTP/HTTPS.
1. Can the Instant AP resolve device.aruabnetworks.com?
From CLI of Instant AP ping device.arubanetworks.com
If no resolution check the Instant AP is configured with a DNS server to send DNS queries to Use CLI command ‘show summary support | include NameServer
2. Can the Instant AP route to device.arubanetworks.com?
If there is no response it may just be that ICMP is blocked along the path. HTTP and HTTPS may still be allowed.
3. Are HTTP and HTTPS blocked by a firewall along the path?
Connect a PC to a port in the same vlan/subnet as the master Instant AP. Telnet to port 80 and 443, on device.arubanetworks.com.
If above is working and still IAP doesn't have cloud activation key, kindly contact Aruba TAC with above details.
Version history
Revision #:
1 of 1
Last update:
‎08-06-2014 01:13 PM
Updated by:
Labels (1)
