What effect do hard reset and purge have on an IAP that is converted to a CAP?
Product and Software: This article applies to all Aruba Instant platforms and versions.
After you convert an Aruba Instant AP (IAP) to a campus AP (CAP), the AP acts as a CAP and holds the configuration that is pushed from the controller.
Purge: When you purge this AP, the configuration that was pushed from the controller is erased and the AP acts like a new, out-of-box CAP.
Hard Reset: When you do a hard reset, this AP rolls back to the factory default and acts like a new, out-of-box IAP.
Version history
Revision #:
1 of 1
Last update:
‎07-02-2014 03:20 PM
Updated by:
Labels (1)
Contributors
