What is the maximum number of VLAN Pooling supported on IAP per SSID?
Question: What is the maximum number of VLAN Pooling supported on IAP per SSID?
Environment: This article applies to Instant Access Points running 4.0.0.x, 4.1.x.x and later
Instant VLAN pooling feature allows a set of VLANs to be assigned to a designated group of users. VLAN pooling is tied to the SSID profile on Instant and each SSID can have different VLANs or VLAN pools.The maximum number of VLAN can be added in a VLAN pool per SSID is 256.
Version history
Revision #:
1 of 1
Last update:
‎11-11-2014 05:54 AM
Labels (1)
Contributors
