What is the maximum number of VLANs supported by Aruba Instant APs (IAP)? What is magic vlan in IAP?
Environment : This article applies to all the IAPs and OS versions.
IAPs support a maximum of 4094 VLANs.  Magic VLAN is the VALN that is reserved on the IAP to provide IP addresses to the guest SSIDs. This VLAN cannot be used for general purpose. VLAN 3333 on the IAP is referred to as magic VLAN.
Magic VLAN (VLAN 3333) provides the clients IP addresses in the range of to and the subnet mask is
For clients to get an IP address from magic VLAN, we need to choose the client IP assignment as “virtual controller assigned”.
From IAP OS version 3.1, the DHCP scope for  the magic VLAN is configurable:
1. Navigate to 'System'. Click on 'show advance option'
2. Click on DHCP tab
3. Configure the required DHCP scope.
4. Click on OK at the bottom.
Version history
Revision #:
1 of 1
Last update:
‎06-30-2014 01:30 PM
Updated by:
Labels (1)
