Whitelist URLs for cloud guest captive portal authentication
MVP
MVP
Q:
How to add Whitelist URLs for cloud guest captive portal authentication ?
A:
From central 2.2.6 we have option to add whitelist URLs under the splash page settings . This defines the URLs that are allowed for the guest users to access in the captive portal initial role i.e before authenticating  to cloud guest
For example, if the terms and conditions configured for the guest portal include URLs, you can add these URLs to the whitelist, so that the users can access the required web pages.
wlan access-rule CP-Test_#guest#_
 index 7
 rule alias bbc.com match tcp 80 80 permit
 rule alias yahoo.com match tcp 443 443 permit
 rule alias gmail.com match tcp 443 443 permit
Version history
Revision #:
2 of 2
Last update:
‎03-24-2017 07:52 PM
Updated by:
Labels (1)
Contributors
