Why DRP config is not pushed to IAP when its enabled through Aruba Central?
Q:
A:
We could see config error in the central when DRP config is pushed through Aruba Central as shown below:
DRP is enabled through Central:
Config error which is highlighted below:
In the IAP CLI we can see the DRP config is not pushed as shown below:
Master IP Address   *:192.168.134.18
IP Address           :192.168.134.18
Netmask              :255.255.254.0
Gateway              :192.168.134.1
NameServer           :192.168.39.180
NameServer           :192.168.39.6
DNSDomain            :ki.com
Master Key           :0349b686017b0cdb94e1e6a7677e0235a27f5d697f79f3c760
Elected Time         :1m:59s
Dynamic Radius Proxy :disable   <===========================
NTP Server           :120.88.46.10
Configuration Dirty  :disable
Allow New APs        :enable
Classification       :disable
Wireless Containment :disable
To resolved this issue, its required to disable DRP first and remove VC IP address.
Configure with different VC IP and enabled DRP which will fix this issue.
If the VC IP address is assigned to other device my mistake, the config cannot be pushed from the Aruba Central.
After assigning new VC Ip address there is no config error as shown below:
Version history
Revision #:
2 of 2
Last update:
‎05-17-2016 04:04 PM
Updated by:
Labels (1)
Contributors
