Why dot1x clients failing Authentication when the termination is enabled on the IAP?
MVP
MVP
Q:
A:
If termination is enabled on the IAP, Dot1x will not work unless if you upload the Radius cert on the IAP.
By default IAP will comes only with WebUi/Captive portal Cert.
Make sure "Radius Proxy" knob is enabled on the IAP and VC ip address is added on the Radius server for successful Authentication.
Version history
Revision #:
2 of 2
Last update:
‎01-04-2016 11:56 AM
Updated by:
Labels (1)
Contributors
