Why ethernet bridging is not working even after enabling the bridging in ethernet profile?
Question: Why ethernet bridging is not working even after enabling the bridging in ethernet profile?
Environment Information: This article applies to all Aruba Instant Access Points.
Symptoms:
Users will not be able to get an IP address.
Users will not be able to pass traffic.
Cause: We need to select the Access Point and click "edit" in order to get the dialogue box to enable ethernet bridging as per below image
2.) We need to select "Enabled"  for "Eth0 bridging" in order to enable bridging on ethernet port 0 as per below image.
3.) After enabling the ethernet bridging on Eth0 we need to edit the wired profile as per below image.
4.) Select the default wired profile which is mapped to Eth0 and click "edit".
5.) By default the Admin status for the wired default profile will be "Down" which is shown in below image.
Resolution: We need to change the "Admin" status to UP as per below image.
AnswerAfter performing all the above steps the users will be able to get an IP address and also pass traffic.
Version history
Revision #:
1 of 1
Last update:
‎10-29-2014 10:16 AM
Updated by:
Labels (1)
Contributors
