Why is that "Wireless Configuration" menu is missing on my Aruba Central account?
MVP
MVP
Q:
A:
Aruba Central is a cloud based managing portal for Aruba Instant Access Points (IAP) and Mobility Access Switches.  One can configure and monitor the IAP cluster and switches remotely. "Wireless Configuration" menu, under the group is where all the configuration can be done. Now, this would get completely missing when all the existing licenses in the account are expired.
Below is the menu from one of a test central account, where the license are expired. We do not see Wireless Configuration in the left
Version history
Revision #:
2 of 2
Last update:
‎11-25-2015 04:20 PM
Updated by:
Labels (1)
Contributors
