Why is the TX power for IAP exceeding the max-tx-power set in the ARM profile?
Problem:
IAP is exceeding the power levels set  in ARM profile.
Diagnostics:
We see that the ARM profile clearly states that power should be limited to 12
arm
 wide-bands none
 min-tx-power 9
 max-tx-power 12
 band-steering-mode prefer-5ghz
 air-time-fairness-mode fair-access
 client-aware
 scanning
 However, on G band we see it is exceeding the max power exceeding 12 on G band:
 show ap bss-table
bss                ess           port  ip            phy    type  ch/EIRP/max-EIRP  cur-cl  ap name            in-t(s)  tot-t
94:b4:0f:e8:2e:70  #test          ?/?   192.168.1.64   a-VHT  ap    52/12/22          0       W-BC03262-APS-001  0        7d:1h:54m:6s
94:b4:0f:e8:2e:71  #test1         ?/?   192.168.1.64   a-VHT  ap    52/12/22          1       W-BC03262-APS-001  0        7d:1h:54m:6s
94:b4:0f:e8:2e:60  #test          ?/?   192.168.1.64   g-HT   ap    11/21/21          1       W-BC03262-APS-001  0        7d:1h:54m:6s
94:b4:0f:e8:2e:61  #test1         ?/?   192.168.1.64   g-HT   ap    11/21/21          0       W-BC03262-APS-001  0        7d:1h:54m:6s
Solution
This issue can happen when below conditions are met:
1. We are using Aruba instant OS below the versions 6.4.4.3-4.2.2.0.
2. We set CSA without configuring dot11h first.
Thus we need to:
1. Upgrade to 6.4.4.3-4.2.2.0 and above. From this code, we will receive an error if we try to configure CSA without dot11h:
ac:a3:1e:c3:2f:50# conf t
ac:a3:1e:c3:2f:50 (config) # rf dot11a-radio-profile
ac:a3:1e:c3:2f:50 (RF dot11a Radio Profile) # csa 5
ac:a3:1e:c3:2f:50 (RF dot11a Radio Profile) # exit
ac:a3:1e:c3:2f:50# commit apply
committing configuration...
Error: Enable dot11h first before set csa-count in dot11a profile.
OR
2. Remove CSA config if dot11h is not configured.
Version history
Revision #:
2 of 2
Last update:
‎11-10-2017 07:46 AM
Updated by:
Labels (1)
Contributors
