Wired-containment for L3 NAT rogue on iAP 4.2.3
MVP
MVP
Q:
A:
Before 4.2.3.0, we did not support wired-containment for L3 NAT rogue.
In 4.2.3.0, we introduce 2 knobs to enable wired-containment to 2 kinds of L3 NAT rogue.
Note:
No UI support
configure terminal
 ids
    wired-containment-ap-adj-mac
    no wired-containment-ap-adj-mac
    wired-containment-susp-l3-rogue
    no wired-containment-sup-l3-rogue
Wired-containment-ap-adj-mac feature contains layer-3 APs whose wired interface MAC addresses are either the same as (or one character off from) their BSSIDs.
ac:a3:1e:cd:3c:4e# show ids aps
Unknown Access Points Detected
MAC Address        Network            Classification  Chan.  Type     Last Seen
d0:c7:c0:32:77:24  000TP-LINK_227724  Rogue           1      GN 40MZ  06:03:11
Log (d0:c7:c0:32:77:24 is a L3-Rogue):
Jan  2 06:10:33  sapd[3562]: <127104> <WARN> |AP ac:a3:1e:cd:3c:4e@192.168.3.251 sapd| |ids-ap| AP(ac:a3:1e:53:c4:e0): AP Wired Containment: An AP attempted to contain an access point (BSSID d0:c7:c0:32:77:24) by disconnecting client (MAC d0:c7:c0:32:77:24) by disrupting device with IP 192.168.3.237 and MAC d0:c7:c0:32:77:23.
Wired-containment-susp-l3-rogue contain an AP with a preset wired MAC address that is completely different from the AP’s BSSID and if the MAC address that the AP provides to wireless clients as the “gateway MAC” is offset by one character from its wired MAC address.
Log (94:b4:0f:9b:0d:72 is a Susp-L3-Rogue ):
94:b4:0f:9b:0d:72  225nat             Suspect-Rogue   52     AC 80MZ  08:31:30
Jan  1 08:03:52  sapd[3595]: <127104> <WARN> |AP ac:a3:1e:cd:3c:4e@192.168.3.253 sapd| |ids-ap| AP(ac:a3:1e:53:c4:f0): AP Wired Containment: An AP attempted to contain an access point (BSSID 94:b4:0f:9b:0d:72) by disconnecting client (MAC 94:b4:0f:9b:0d:72) by disrupting device with IP 192.168.3.242 and MAC 94:b4:0f:c1:b0:d5.
Version history
Revision #:
2 of 2
Last update:
‎03-29-2017 04:32 PM
Updated by:
Labels (1)
Contributors
