With Eval licnse of Aruba Central, how many IAPs and Mobility Access Switches can be managed?
MVP
MVP
Q:
With Eval license of Aruba Central, how many IAPs and Mobility Access Switches can be managed?
A:
Aruba Central is a cloud-based platform that enables you to manage your Aruba wireless network. Designed as a software-as-a-service (SAAS) subscription, Central provides a standard web-based interface that allows you to configure and monitor multiple Aruba Wi-Fi networks from anywhere, provided you have an Internet connection.
As an Aruba Central EVAl customer, one would get the following licenses:
  • EVAL IAP license valid for 90 days with an ability to manage 5 IAPs
  • EVAL MAS license valid for 90 days with an ability to manage 2 Mobility Access Switches.
Once EVAl account is created, one can navigate to "subscription keys" menu under "maintenance" to check out the licenses:
NOTE: The "subscription keys" menu under "maintenance" is active only when you are in "All Groups"
Below is a sample screenshot:
Version history
Revision #:
4 of 4
Last update:
‎11-25-2015 01:46 PM
Updated by:
Labels (1)
Contributors
