enet0_bridging gets enabled accidentally
Symptoms
Why is Aruba Instant not able to get IP address after reboot and works on factory reset?
Why did enet0_bridging get enabled on reboot after CLI configuration?
Diagnosis
Any Aruba Instant running code version 6.2.1.0-3.4.0.1 or older
CLI configuration was being done on Access Point and on reboot; AP doesn't get IP address / doesn't come up.
Solution
Aruba Instant doesn't have an additional enable mode with enable password. When logged in with admin credentials; user can directly execute show / action commands.
Out of habit; admin user may accidentally execute "en" command. As the only match is "enet0-bridging"; it would get enabled. Since enet0-bridging is an action command; it can be enabled without entering config mode and the effect takes only on reboot.
6c:f3:7f:c4:0b:6a# en?
enet0-bridging
6c:f3:7f:c4:0b:6a# reload
The system is going down NOW !!
Sending SIGTERM to all processes.
Jan 1 00:02:52 udhcpc[1094]: Received SIGTERM
Sending SIGKILL to all processes.
Please stand by while rebooting the system.
Restarting system.
APBoot 1.2.6.7 (build 30025)
Built: 2011-08-30 at 17:41:16
Model: AP-13x
CPU: 88F6560 A0 (DDR3)
Clock: CPU 1600MHz, L2 533MHz, SysClock 533MHz, TClock 200MHz
DRAM: 256MB
POST1: mem 0 mem 1 mem 2 mem 3 passed
Flash: 16 MB
Power: 802.3at POE
LAN: done
PHY: ....done
PEX 0: RC, link up, x1
bus.dev fn venID devID class rev MBAR0 MBAR1 MBAR2 MBAR3
00.00 00 11ab 6560 00005 02 f1000000 00000000 00000000 00000000
00.01 00 168c 0030 00002 01 90000000 00000000 00000000 00000000
PEX 1: RC, link up, x1
01.00 00 11ab 6500 00005 02 f1000000 00000000 00000000 00000000
01.01 00 168c 0030 00002 01 94000000 00000000 00000000 00000000
Net: eth0, eth1
Radio: ar9390#0, ar9390#1
Hit <Enter> to stop autoboot: 2 0
apboot> print
bootdelay=2
baudrate=9600
autoload=n
boardname=Arran
servername=aruba-master
bootcmd=boot ap
autostart=yes
bootfile=armv5te.ari
ethaddr=6c:f3:7f:c4:0b:6a
os_partition=0
enet0_bridging=1
stdin=serial
stdout=serial
stderr=serial
ethact=eth0
To recover the following can be done ::
factory reset the AP (if there is source to get the config and there is no static config on AP)
From apboot>; execute purge (if there is no other static config)
From apboot> execute; setenv enet0_bridging
apboot> setenv enet0_bridging
apboot> save
Saving Environment to Flash...
Un-Protected 1 sectors
.done
Erased 1 sectors
Writing
apboot> printenv
bootdelay=2
baudrate=9600
autoload=n
boardname=Arran
bootcmd=boot ap
autostart=yes
os_partition=0
stdin=serial
stdout=serial
stderr=serial
ethact=eth0
To avoid this accidental enabling of enet0_bridging; a no-operation i.e. dummy enable command has been included starting from 6.2.1.0_3.4.0.2
enable
enet0-bridging
% Incomplete command.
Version history
Revision #:
1 of 1
Last update:
‎06-01-2014 08:21 PM
Updated by:
Labels (1)
Contributors
