Occasional Contributor I
6.1 to 6.2 upgrade tunking issue
Open SSID on vlan 7
WPA2PSK on vlan 4
IAP on vlan 4
Everything works fine on 6.1, when they IAP is upgraded to 6.2, the Open SSID on vlan 7 traffic is not bridged to the wire. The AP is plugged into an Aruba s2500 running Version 7.2.0.0
Here is the config on the switchport:
interface-profile switching-profile "IAP"
   switchport-mode trunk
   native-vlan 4
MVP
Re: 6.1 to 6.2 upgrade tunking issue
[ Edited ]
regarding your s2500 - here is example of full cli command on how to interface-profile switching-profile should be built - ( u may try to add the trunk allowed vlan all command - and see if it's solved your issue)
interface-profile switching-profile {default|<profile-name>}
clone <source>
access-vlan <vlan id>
native-vlan <vlan id>
switchport-mode {access|trunk}
trunk allowed vlan [add|all|except|remove] <vlan list>
storm-control-bandwidth <50-100>
storm-control-broadcast
storm-control-multicast
storm-control-unknown
no {...}
exit
lets us know if it's solved your issue.
me
We have trunk allowed vlan allow all configured. This is something that works fine on 6.1, but not 6.2
