Super Contributor II
6.3.1.2-4.0.0.4
Recently I downloaded this version of Instant code. I checked to see if there were any newer versions but I looks this version is now missing from the website - has it been withdrawn or am I looking in the wrong place?
Re: 6.3.1.2-4.0.0.4
Sorry, found it - I was looking in the documentation sections.
Valued Contributor I
Re: 6.3.1.2-4.0.0.4
4.0.0.5 is the most current version.  Just curious if there is a reason for not using this version?
MVP
Re: 6.3.1.2-4.0.0.4
The only reason I don't run the latest incremental releases is my 4-6 week lab and pilot process. About the time I'm finishing testing and preparing to roll new code, Aruba comes out with something newer.
I do drag my feet on ...0 releases to see what needs fixing before I start actively testing at ...2 or ...3
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
Frequent Contributor I
Re: 6.3.1.2-4.0.0.4
Clicking "check for new firmware" in the IAP interface shows nothing newer than 4.0.0.4 is my guess.
