802.11n and 5 Ghz on iap-205-rw
hello,
is iap-205-rw support 802.11n ?
205 yes but -rw version i can't find
when i scan network, ssid is reported as 802.11b/g and performance is really slow
all others 39 ssid (where i am) are 802.11n, only 3 are 802.11b/g
also i don't know why but if i only enable 5 GHz radio, i can't see ssid on 3 laptops (1 is recent : lenovo 450)
Re: 802.11n and 5 Ghz on iap-205-rw
please delete, i'm going to post this in instant category
What channel is the AP on?  There is 2.4 ghz 802.11n and 5ghz 802.11n  if your client does not support 5ghz, it will not see the 5ghz radio on the access point.
thanks for your response
i'm really upset, it seems i don't have any 5 Ghz capable device in 2016
