80MHz channel
In AP regulatory domain, the 80MHz channels are unchecked but still the APs are using 144E channel. VHT, HT, 80MHz support is enabled. Even if everything is enabled and if the channels are not selected under the AP regulatory domain, the AP should not use those channels. Is that correct? If yes, why are they still using 80MHz channels?
Re: 80MHz channel
What operating system version is this?
Re: 80MHz channel
Hi Collin,
It is 6.4
Thanks in advance.
Re: 80MHz channel
Channel Width is selected in the ARM profile.  Channels to be used are selected in the regulatory domain profile.  If all channels for the width specified in the ARM profile are unchecked, it will revert to using all non-DFS channels for that regulatory domain for that width.
Re: 80MHz channel
Thank you for your response. We have DFS channel used.
Re: 80MHz channel
Type "show ap arm history ap-name <name of ap>" to see why the access point has switched to that channel.
