AP-105 reset after firmware upgrade?
In Airwave is still showing AP-105's as "Applying Firmware Upgrade after 2 days?
11 A/N AND 11B/G/N Lights are Red on the AP' 105's?
Re: AP-105 reset after firmware upgrade?
Try to physically give them a reboot by unplugging at the switch.  I often find during an upgrade that there may be one or two APs that become stuck, and a reboot usually helps.
ACCP, ACMP, ACMX #294
mclarke@arubanetworks.com
MVP
What version of Airwave?
We had that happen a few times some versions ago, but in 7.7.3 I pushed upgrades to 500+ iAP in 34 swarms with no stuck devices, and only one swarm which had to try the job a second time.
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
