AP-207 running Officeconnect configured to Aruba Instant
Hi there I have a APIN0207 access point.  It is running OfficeConnect but I would like it to run Aruba instant.  I would like to add it to a cluster of IAP-205's.  Is it possible, and how do I navigate the 207's existing UI to get somewhere that I can re-image/update firmware to Aruba instant?
Thanks for your help.
Aruba
Re: AP-207 running Officeconnect configured to Aruba Instant
No. An OC20 is a different product, even if it shares the same regulatory model number (and a lot of the hardware) with IAP-207 and AP-207 (APIN0207). It can not be converted or upgraded to run Instant.
/Onno
Thank you for your help!
